What Am I Doing Wrong?
Discussion in 'Homework Help' started by bembe 24, Aug 10, 2016.
  1. bembe 24
    Aug 10, 2016
    10
    My solution:
    Is answer correct? can someone verify my solution... thanks :))
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    For me solution looks good, but you could write them differently.
  3. bembe 24
    Aug 10, 2016
    10
    but is my answer already correct?
  4. DGElder
    Member
    Apr 3, 2016
    347
    87
    C1 + C2 = 1/(1/C1 + 1/C2)
    and where does it say C1=C2=C?
  5. bembe 24
    Aug 10, 2016
    10
    so does that make the final answer
    Ls/(Cs/2 +Ls) ??
  6. bembe 24
    Aug 10, 2016
    10
    can i really neglect R in the circuit?
  7. bembe 24
    Aug 10, 2016
    10
    correct me if i am wrong. If I neglect R in the circuit then C1, L and C2 are in series right?
  8. DGElder
    Member
    Apr 3, 2016
    347
    87
    That is not even a solution because C is undefined.
  9. DGElder
    Member
    Apr 3, 2016
    347
    87
    They are in series whether you neglect R or not.
    The answer is not dependent on R.
  10. bembe 24
    Aug 10, 2016
    10
    im sorry my bad. not solution but an equation
  11. bembe 24
    Aug 10, 2016
    10
    so if C1, L and C2 are in parrallel, then rewrite the equation with respect to the impedance then does this make
    1/Cs + Ls + 1/Cs right?
  12. DGElder
    Member
    Apr 3, 2016
    347
    87
    Where in that circuit is there a component called C? There is none.
  13. DGElder
    Member
    Apr 3, 2016
    347
    87
    Is it possible you think the s in Cs stands for series? :eek:
  14. bembe 24
    Aug 10, 2016
    10
    its a transfer function. from time domain to s-domain. that is what s means
  15. DGElder
    Member
    Apr 3, 2016
    347
    87
    It is a complex number used as the frequency parameter in Laplace transforms. I am glad you know it does not stand for series. So moving on....
    What is the solution to your circuit?
    AND.
    If:
    R = 2000 ohms
    C1 = 3 F
    C2 = 6 F
    L = 5 H
    What is the transfer function?
  16. bembe 24
    Aug 10, 2016
    10
    there were no given values of each component. What you see is what you get :D. Its just a constant variable.
    TF = 5/90s^2 + 9
    is it correct??
  17. DGElder
    Member
    Apr 3, 2016
    347
    87
    It is not correct. I can't help you if you don't show me each step of how you got to your solution.
    Just giving you the answer will teach you nothing.
  18. WBahn
    Mar 31, 2012
    18,085
    4,917
    As has already been noted, you can't just assume that C1 and C2 have the same value. So your solution must reflect this reality.
    Also, you need to pay attention to order of operations.
    1/Cs is equivalent to (1/C)s which is equivalent to s/C.
  19. bembe 24
    Aug 10, 2016
    10
    sorry low quality cam :(
    i followed all your instructions. Is this correct?
  20. DGElder
    Member
    Apr 3, 2016
    347
    87
    "Sorry" doesn't make it any more visible.
    If it says what I think it says it is not correct. The setup is correct but your algebra is wrong somewhere and since, once again despite requests, you show none of your steps I can't help you. Maybe you have no steps and are just guessing. Either way I can't help you.
    Also, I think your notation is misleading if not incorrect. It looks like you are subscripting s: s1, s2. There is only one s. Subscript the capacitors: C1,C2. Where applicable, putting s in front of C would make it more legible.
