wet computer monitor
Discussion in 'General Electronics Chat' started by jut, Dec 21, 2009.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    I found a CRT computer monitor on the curb thats been rained on. If I dry it for a few days do you think it will work? Would anything be permanently damaged inside b/c of the water? I'm a little hesitant to even turn it on.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If it was left on the curb, it was put there for a reason.
    "Functioning perfectly" was probably not the reason.
    Getting it soaking wet may or may not help the problem.
    A long time ago, I took the chassis out of an old tube-type TV that was covered in dust, spider webs, and other nasty stuff. I hosed it down quite well and left it to dry in the sun for several days.
    I put it all back together - and wouldn't you know, it actually did work.
    Lately, monitors tend to fail due to HV problems (flyback transformers are a primary cause).
    At any rate, if you let it dry out for several days, you probably won't cause it any more harm.
  3. jut
    Aug 25, 2007
    224
    So I let the monitor dry out near a space heater for about 5 days and then opened the case and used a heat gun (about 3 feet away from) the monitor to make sure no moister was still in there. I powered it up with a PC attached and it works just fine. :)
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It probably got tossed in favor of an LCD monitor.
  5. jut
    Aug 25, 2007
    224
    Yup. This thing is probably 75 lbs and almost 20 inches deep.
