weslo sl20 treadmill
Discussion in 'The Projects Forum' started by dsmithss66, Jan 22, 2012.
  1. dsmithss66
    Jan 22, 2012
    I have a mc60 controller board the control center works the incline goes up and down. all the leds works as they are supposed to I have hooked up a 12v source for the motor and it runs I check the voltage on the output to the motor with the motor disconnected I get around 57.0 volts and when I hook up the motor the voltage goes away pretty sure the motor is not bad and took the choke transformer out of the circuit motor will still not turn did find one resistor that was broke r15 47k replaced it still not luck. I am thinking it something wrong with the mc60 controller.
  2. R!f@@
    Apr 2, 2009
    8,789
    771
    Are u sure the motor is rated for 12V operation.
    I believe u need mains voltage for it to operate
  3. mik3
    Feb 4, 2008
    4,846
    63
    It can be the capacitor after the rectifier. I think there is a rectifier for converting AC mains into DC.
