Hi all,
Longtime tinkerer, tech savvy, but a newbie with actual circuit design. First post.
I have a 2-button keyfob and would like to connect it to a WeMo Maker relay to perform the following two behaviors:
Close wemo relay (ON state): "Press" or activate (pulse) keyfob button A momentary switch
Open wemo relay (OFF state): "Press" keyfob button B switch
Is there a simple circuit I can build between the wemo maker and the keyfob that will result in this behavior? The keyfob is powered by a standard 2532 button cell, I believe.
Thanks in advance!
Nello
Thanks in advance!
Nello
