Weller WS81 fail please help
Discussion in 'General Electronics Chat' started by kwm488, Jan 26, 2014.
  1. kwm488
    Jan 26, 2014
    Hi
    I own Weller ws81 and used 1.5yr. But the fuse is keeping blow now.
    I did follow to fix it. But it doesn't work.
    1. I replace Triac (BTA12-600B). The fuse is not blow now. I can turn on solder. But the fuse will blow again after 30sec. It looks like the new triac dead again.
    2. I guess the solder heater short. So i replace solder heater and traic. But the fuse keep blow.
    3. I think ic have problem. I change all ic in the pcb. But it is the same.
    4. I checked all smd resistor. It is no problem.
    Last, the transformer voltage is correct
    Please help
  2. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    Did you check the resitance of the iron like in the manual? ???
  3. kwm488
    Jan 26, 2014
    Hi
    I checked all resistor. All resistor no problem.
    Please help
