Weller WLC100
Discussion in 'General Electronics Chat' started by Gdrumm, Mar 23, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I was trying to do a little soldering in my garage today.
    It seemed the iron was cycling on an off.
    I turned it all the way up, and it wouldn't melt the solder.
    I believe this has a rheostat inside, can that be cleaned?
    The temperature in the garage was about 60=65 degrees.
    Does the cool weather affect the ability of the iron to melt the solder?
    I cleaned the tip repeatedly, and not much improvement.
    I just put a new tip on it a couple of weeks ago, and it was working fine.
    Any ideas?
    Thanks.
  2. Gdrumm
    Aug 29, 2008
    684
    36
    On Ebay, they sell pocket oscilloscopes anywhere from $35.00 to $200.00
    For a novice, would an inexpensive one be a good purchase?
    Just as a leaning device, (although I have had large ones in the past, and I do know a little bit about them).
    Is the small screen an issue?
    Are there any other concerns?
    I don't have much workspace, so I thought one of these might work.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If the soldering iron has an electronic temperature controller with a "trimpot inside" you should be able to diagnose it with a multimeter (which I assume you have?).
    If you post some good photos of the control PCB and the wiring it will really help people trying to help you.
    Re the little ebay DSO-nano type 'scopes, they can be excellent compared to no 'scope at all. I think the latest Nano can be bought around $60? I doubt that you would regret that purchase, even if you buy a large 'scope later to do high frequency work.
  4. Gdrumm
    Aug 29, 2008
    684
    36
    Thanks,
    I'll try to post photos tonight.
    Gary
