My Weller WES51 has served me nicely however it just started to act up. It works for a bit then quits. The board has several test points on it but I can't seem to find a schematic or service manual for this device to trouble shoot it properly.
So far I've - Tested all points to satisfaction as per the owners manual (required resistances etc.), taken the iron apart and checked for loose/broken wires, tested the transformer output at 24V and confirmed a steady 5V voltage regulator output on the board. If I disconnect the iron and test the output pins for the required 24V I get a fluctuating voltage which I would presume is temp regulation at work but the darn thing won't heat up. Would a bad tip cause this effect? It's a weekend and I can't get a new tip until Monday.
I'd hate to scrap it without a fight.
