If it is you are in the middle of RF theory. There is a reason they use special wire to carry TV signal to TVs. It won't damage the TV unless you do something way out, such as feeding spikes from the coil into the coax line, but you are messing with a carefully constructed RF path by using a simple relay (this sounds worse than it is).
Unless it is going to cause you problems I wouldn't worry about it.
BTW, what part of the world are you? It helps because we can make assumptions about the local standards.
To bertus, i dont have a scematic as i was jusr playing around, this was a long time ago and i am sure i was trying to connect two relays to latch for a light activated spotlight to come on, and then off with another ldr, i remember that if i connected it in a certain wat the relay would flick in and off wildly, but when it was disturbing tne Tv's i THINK it was humming trying to click, Bill i am in Australia and the coax was not connected in any way, i was just playing with the relay and i noticed the tv it was some sorta wireless disturbence maybe a certain RF signal Chris
Each time a relay coil is switched off, it produces a high-voltage spike (which is why snubbers or flywheel diodes are normally added).
Without any suppression, this high voltage will arc back across the contact switching the coil. Each time this happens a burst of wide band radio noise is produced.
With the relays buzzing, you would be producing many noise bursts per second - a fair radio jammer!
Haha lol yes thats rite SgtWookie, and to Mr Jenkins what you explained how does this work radio jammer? How did it effect the Tv just from a switching relay, how would i recreate this for old times sake? Chris
