Weird flip flop trigger behaviour?
Discussion in 'General Electronics Chat' started by robijnix, Mar 8, 2013.
  1. robijnix
    Feb 23, 2013
    7
    I recently got some pos edge 8 bit flip flops, so i decided to test them by connecting the flip flop to an adder and see what happens:
    http://www.youtube.com/watch?v=TxZwYjTYRE4
    I would have expected the value to increase by 1 every time i make the clock high (that's what i do with that wire in my hand), but as you can see, it sometimes increases by more than 1.
    now i wonder why this is. I thought i might be because when putting the clock wire into the hole i might be making a few very short contacts with the hole before i keep it steady, and it trigger on each of those contacts?
  2. JDT
    Feb 12, 2009
    658
    85
    Exactly!
    You need a simple circuit like this using a change-over switch to remove the contact bounce.
    robijnix likes this.
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    Yes, I think you're right.
    A bit on de-bouncing switches:
    http://www.elexp.com/t_bounc.htm
  4. robijnix
    Feb 23, 2013
    7
    Thanks, thats actually a pretty nice solution.
  5. sheldons
    Oct 26, 2011
    616
    101
    orrrr there is this one......the section built around a 4093 is the switch debounce section that will work for you
