Wein Bridge Oscillator
Discussion in 'General Electronics Chat' started by eminthepooh, Sep 27, 2012.
  1. eminthepooh
    Aug 26, 2012
    27
    Hey guys, been killing myself trying to debug this thing.
    I have this circuit which is supposed to be an oscillator, but I don't see any oscillation on the output. All is quiet on the pin 1 front.
    Anyone spot a problem? I'm lookin to get a 10kHz sine wave, which is definitely within the bandwidth of the opamp. Went from 0-100K ohms on the pot as well, nothing produces any output.
    The opamp works tho, I can get a simple feedback system going on it, just not this oscillation.
    any and all help will be appreciated.
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. JDT
    Feb 12, 2009
    658
    85
    I would have expected R1 and R2 resistors to be a larger value. Also, the 15pF capacitors should also be much larger value. Otherwise the oscillation frequency is going to be very high - possibly too high for the op-amp. Was there a misprint on your original circuit diagram?
    Try changing so that both resistors are 10k (or higher) and fit larger capacitors (say 1.5nF). See if it oscillates then.
    After that, if you want a higher frequency, adjust the values of the capacitors in small stages. Check that it oscillates each time.
  4. Dodgydave
    Jun 22, 2012
    5,156
    772
  5. t06afre
    May 11, 2009
    5,939
    1,222
    As a general rule of thumb. I try to avoid using resistors as high as 1Mohm. in opamp circuits. 15PF is also a quite small. Stray capacitance that you find in all circuits may influence on your result. Then using so small caps. Try using 4.7nF caps, and 3.3Kohm resistors. That should give you about 10KHz. In such circuits pick the caps first. Then the resistors. As it more easy to match values this way
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    Why are your timing resistor values so darn low?
    Why are your timing capacitor values so darn low?
    The extremely simple circuit is missing parts to stabilize the output level so when the resistor and capacitor values are corrected and when the pot is adjusted for oscillation to occur then the output will be a square-wave.
  7. eminthepooh
    Aug 26, 2012
    27
    Thanks for your input everyone. The R and C values do multiply to give me 10khz, but I suppose they were too small.
    I tried with 220k ohm and a couple bigger caps sitting around and got 25khz.
    Appreciate all the help guys!
  8. t06afre
    May 11, 2009
    5,939
    1,222
  9. Ron H
    Apr 14, 2005
    7,050
    657
    1/(2*pi*15e-12*1e3)=10.61MHz.
    You have gotten your units confused.
