blocco a spirale
- Joined Jun 18, 2008
- 1,546
Yes, you just need a suitable solenoid valve controlled by a timer. You can build a timer, but I would just buy a programmable timer relay.
If you could get them to gather in a tube, e.g. 100 to 150mm plastic drainpipe, you could fire them them out the end, and through a one-way flap valve, into the collection container with a blast of compressed air. That way, they would have no choice in the matter. This method also has the advantages of very few moving parts and the absence of any powered door mechanism means it is unlikely to trap or injure the crickets
Or use a filter over the shop vac hose (woman's knee high stocking) to prevent anything being sucked into the vac.<snip> Too much vacuum airflow could suck them through the jar and into the shop-vac . But , maybe this would not be a problem anyway , just suck them into the shop vac and not use the jar at all .
by Aaron Carman
by Aaron Carman
by Jake Hertz
