Wear goggles when working with LEDs.
Discussion in 'General Electronics Chat' started by jaygatsby, Feb 20, 2013.
  1. jaygatsby
    Nov 23, 2011
    185
    23
    I'm sure glad I did...
  2. tshuck
    Oct 18, 2012
    3,531
    675
    ...and that's why you should always use a current-limiting resistor:p....
  3. timescope
    Member
    Dec 14, 2011
    298
    44
    You need goggles because you did not put a current limiting resistor in series with the led.
    Timescope
  4. jaygatsby
    Nov 23, 2011
    185
    23
    The bus was connected to a current source
  5. tshuck
    Oct 18, 2012
    3,531
    675
    To be clear, this was a constant current source at what current?
  6. jaygatsby
    Nov 23, 2011
    185
    23
    Constant as long as I didn't change it... it was illuminated for a little bit then I decided to crank it to max to watch the fireworks.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    Well there's the problem: you're a pyro!:p
    EDIT: So, the title should probably read, "Wear Goggles when attempting to explode a LED"!
  8. bug13
    Feb 13, 2012
    1,214
    38
    how much current did you pump through??
  9. #12
    Nov 30, 2010
    16,704
    7,354
    I get nostalgic when I hear the familiar crackle of exploding thermoplastic.:D
  10. jaygatsby
    Nov 23, 2011
    185
    23
    I dunno exactly but I bet it was up around an amp.
  11. jaygatsby
    Nov 23, 2011
    185
    23
    Maybe I'll reverse bias a bunch of caps and put them with LEDs on the bus, I wonder if my canon camera has good enough res to make it into slow motion...
  12. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    This reminds me of a video that there is on YouTube.. someone discharges a bank of capacitors, charged to in excess of 200V using a diode. Of course in one direction no current flowed and everything was okay, but when he connected it in the other direction the rating on the diode was far too low and it exploded! The guy then said "ouch" or similar and then commented that goggles might of been a good idea!
  13. mcgyvr
    Oct 15, 2009
    4,791
    976
    or the idiots on youtube with a large capacitor bank blowing up watermelons
  14. PackratKing
    Jul 13, 2008
    850
    216
    Precicely why we need to be careful who we pass knowledge to, counting all the absolute fools out there...
