Actually, I have no problem with your suggestion. Just pointing out that they are in many ways comparable.
What would be really nice would be for members, as part of their profile, to set up filters for how posts and threads are displayed, primarily by background shading, perhaps. For instance, if you've put someone on your Ignore list, then any post by them has a soft red background. If you've put a thread on your Do Not Respond list, then all posts in that thread show up with a soft brown background (and you could pick the color, I'm just throwing out an example). Posts that are older than some user-defined limit would have a yellow background. Similar rules could be set up for the list of threads at the forum level, too. Posts by people you follow might have a soft green background. You could order the criteria to dictate which one wins if, for instance, someone you follow posts a response in an old thread that you don't want to respond to. Or you could set multiple criteria to use yet another shading option. The rule descriptions are simple enough (most spreadsheets support something similar), take up virtually no room in the profile database, and execute efficiently as part of the database query process.
