ways to take the outside temperature
Discussion in 'General Electronics Chat' started by steven334, Jan 9, 2012.
  1. steven334
    Aug 9, 2011
    37
    I would like to design a circuit to turn on and off the heat in my house, and to record the data, (Time, Temperature, and Heat on or off).
    First I have a few questions.
    Are there more sophisticated ways to take the outside temperature? Can I get something like the AccuWeather RealFeel Temperature?
    Should I make a sophisticated temperature circuit or can my circuit get better temperature data from the internet?
    Thank You I appreciate any advice you may have to get me started.
    Steven
  2. jimkeith
    Oct 26, 2011
    539
    99
    I would not depend upon the internet except for recording data--for heating your house, take your own measurements
  3. steven334
    Aug 9, 2011
    37
    should i just use the TMP36 - Temperature Sensor and be done with it?
  4. DumboFixer
    Feb 10, 2009
    219
    34
    If you are wanting to heat your house would it not be better to measure the temperature insude the house ?
    After all the property may be well insulated so that with it being cold outside it may be nice and warm inside. Having an external sensor will trigger the heating when it isn't required and thus costing you money.
  5. steven334
    Aug 9, 2011
    37
    I need to take both inside and outside temperatures.
    Outside is more for data collection than to turn on/off heat.
  6. steven334
    Aug 9, 2011
    37
    how does
    Digital Temperature Sensor Breakout - TMP102
    differ from
    TMP36 - Temperature Sensor?
