Ways to measure audio noise level?
Discussion in 'General Electronics Chat' started by MikeA, Jan 28, 2015.
  1. MikeA
    Jan 20, 2013
    125
    17
    I'd like to sample ambient noise once every 15 seconds. What about this idea: electret mic -> op-amp -> capacitor with a high value resistor to ground. Then an ADC will sample the voltage on the cap every 15 seconds. Is this a reasonable and straight forward way to accomplish this?
  2. #12
    Nov 30, 2010
    16,665
    7,313
    You need a precision rectifier in there to give a unipolar peak level.
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    No. If you sample every 15 seconds, the highest frequency you can measure is 0.03Hz according to the sampling theorem.
    What kind of noise do you want to measure? White, pink, brown, blue, violet, grey?
    Colors of noise
  4. #12
    Nov 30, 2010
    16,665
    7,313
    It took me most of a minute to figure out what you said, MrChips.
    I assumed MikeA wanted to find the general loudness level of the background noise. Kind of like taking a photo of a db meter every 15 seconds.
    I guess we're about to find out.
    planeguy67 likes this.
  5. wayneh
    Sep 9, 2010
    12,377
    3,231
    That was my assumption as well.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Yes, I understood your idea even before you posted (amazing, isn't it?).
    What you are proposing is to rectify the AC signal and measure the sound envelope. That will work also.
    I wanted to put some theory up front on the table for the OP to understand.
  7. #12
    Nov 30, 2010
    16,665
    7,313
    I know you think differently from me, and that is a major part of why this forum is good. It's just that sometimes I have to back up a step to get on your track.;)
  8. MikeA
    Jan 20, 2013
    125
    17
    For now I'd like to measure just an average noise level. Bringing in a peak measurement might come in the future. :D
  9. #12
    Nov 30, 2010
    16,665
    7,313
    Average compared to peak is just a 2 resistor voltage divider, (and you're going to do that at the averaging capacitor anyway). You can add that circuit before or after the precision rectifier, but you can't easily build an, "average" rectifier that works properly across a wide range of amplitude.
    It's just: Mic---precision rectifier---resistor--capacitor---resistor.
    or you can do: Mic---resistor---resistor----precision rectifier---resistor---capacitor---resistor.
    The second method rectifies the average instead of the peak, but it needs more parts to get to the same place.
  10. MikeA
    Jan 20, 2013
    125
    17
    Is there a sample circuit diagram that I can look at to wrap my brain around this? :oops:
  11. #12
    Nov 30, 2010
    16,665
    7,313
    Here's a start. One of them shows the secret internals of an electret mic and the other is a peak detector with gain.
  12. joeyd999
    Jun 6, 2011
    2,756
    2,922
    You have just stoked my curiosity, #12. Why do you suggest a differential amp for an electret? In what way is that better than single-ended?
  13. #12
    Nov 30, 2010
    16,665
    7,313
    I did not mean to suggest a differential amplifier. That's just the drawing I had available in less than 3 minutes. It shows that an electret mic needs some power supply and can be connected to the input of an op-amp.
    That one also has a switchable filter on it for some reason I can't remember.
    That's what the OP needed that day...whatever day that was.
  14. joeyd999
    Jun 6, 2011
    2,756
    2,922
    Boy, you are just one big enigma today.
    Ok...well, for the sake of the OP, a cursory (not rigorous!) analysis of the differential circuit tells me it might not work so well. Buyer beware....
    #12 likes this.
  15. #12
    Nov 30, 2010
    16,665
    7,313
    It was right for some other person on some other day. That drawing just needs a LOT of circuitry chopped off of it for today's job.
    Like this:
  16. ronv
    Nov 12, 2008
    3,393
    1,452
    Range may be a problem. What is quiet? Like the bedroom at night or like normal conversation. And loud?
    #12 likes this.
  17. #12
    Nov 30, 2010
    16,665
    7,313
    Maybe I should make those 2 resistors on the + input of the op-amp a volume control?
  18. MrChips
    Oct 2, 2009
    12,624
    3,451
    OP/TS needs to say what he wants to do with this information.
    He may want to consider using a log amplifier.
    #12 likes this.
  19. #12
    Nov 30, 2010
    16,665
    7,313
    You're right. There is a HUGE range of loudness levels and a log amplifier could make a much more useful output range.
  20. studiot
    Nov 9, 2007
    5,005
    515
    It's nice to know that there are at least two members of this forum that think.
