Ways to fry a transistor
yamanq
Joined Feb 24, 2016
I am new to circuitry, and while working with transistors, I believe that I have fried them (they are always open). I found online that placing them the wrong way fries them, but does application of a lot of voltage also fry them? Is there a way to fix them?
I am working with 2N2222A transistors and the voltage that I applied was 9V.
Thank you in advance
Edit: Schematic:
Joined Nov 30, 2010
18,224
No resistors means no limit to the current. You have exceeded the current rating of your transistors. They can not be repaired.
WBahn
Joined Mar 31, 2012
29,979
Your schematic doesn't make much sense. You are showing a currents in the transistor going the opposite direction they should -- and this is reflected in the very low current gain of one (how realistic that is I'm not sure).
You also have an emitter-base voltage of 3.6 V. This part was an absolute max for that voltage of just 6 V, so that can get you in trouble, too.
atferrari
Joined Jan 6, 2004
4,764
Nice color beans! Or it is dots? Do they move ? If so, in what direction?
What if the OP posts a schematics drawn in a non-fancy way?
34,285
(Some) Ways to fry a (BJ) transistor:
Exceed the base-emitter maximum current rating.
Exceed the base-emitter maximum reverse-voltage rating.
Exceed the collector-emitter or collector-base maximum voltage rating.
Exceed the collector-emitter maximum current rating.
Exceed the transistor maximum junction temperature (power) rating.
All of the above values can be found in the transistor data sheet under "Absolute Maximum Ratings".
Sounds like you may have exceeded at least one of those in your experimenting.
Note that the normal direction of base-emitter and collector-emitter current flow in a BJT is in the direction of the base-emitter arrow (opposite of what you show).
Perhaps you should read up some more on how transistors work. :rolleyes:
WBahn
Joined Mar 31, 2012
29,979
And don't feel too bad about frying transistors -- it's one of the more effective ways to learn about this stuff and you are asking the right questions.
Bordodynov
Joined May 20, 2015
3,177
This scheme uses a reversible mode transistor. When using the default transistor, this transistor has Beta_forvard = 100 and Beta_revers=1. Then, the emitter current (revesny mode) is the base current (emitter current=base current x Beta_revers) and collector current is the sum of the base and emitter currents. All this occurs in the presented image.
I do not understand why is used reverse mode, but each in its perverted. There are relaxation oscillators that use this mode.
Willen
Joined Nov 13, 2015
333
Hi ferrari,
The program is called EveryCircuit and it's android app for android OS phones. The application simulates circuits and these beans moves and wave form swings (visualization of operation of circuit). For the beginner, it seems very nice simulator. But it's not totally free, just single stage of limited drawing area is free.
GopherT
Joined Nov 23, 2012
8,009
If you are not able to track down any current limiting resistors, Yoou might want to look into a silicon carbide transistor. Able to glow red hot - above 650C - and function normally.
Good luck.
http://m.powerelectronics.com/power...rying-pan-fire-no-problem-silicon-carbide-ics
