ways on testing IC that is bad
Discussion in 'Electronics Resources' started by jerry05, Jun 11, 2013.
  1. jerry05
    Jun 11, 2013
    28
    how can i know that an IC is not working with multimeter
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    You can't.
  3. GopherT
    Nov 23, 2012
    6,304
    4,027
    ICs need to have power and an input signal as a minimum. Even then, you will only be able to test basic functions. Beware of switch-bounce if you are manually checking counters/flip-flops. You cannot expect a manual switch to issue a single pulse.
    Also, any frequency sensitive issues will not be tested with manual switching for a minimal test.
    Any microcontroller/ROM/RAM/or other programmable chip will be untestable without a program or controller.
  4. jerry05
    Jun 11, 2013
    28
    then how can you know that ic is bad
    so if the chip is programmable how can i check if its bad
  5. gerty
    Aug 30, 2007
    1,154
    304
    Why don't you give us all the information at once, instead of a little at a time. With that we can give you a better answer.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    You know the IC is bad when it doesn't perform its function.
