Waveform Generator Problem
Discussion in 'Homework Help' started by callum2510, Sep 7, 2015.
  1. callum2510
    Aug 26, 2015
    9
    Hi, Just looking for some verification if I have complete this correctly? I'm not 100% sure on my solution. Screen Shot 2015-08-28 at 10.31.32 am.png media-867-867f15cc-b9a9-4289-9e3c-425f15e5222b-phpSTCI5Y.png
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    It is incorrect to say that the inputs of the first opamp are at virtual ground. The term "virtual ground" means that the voltage is 0V (i.e., the same voltage as your "ground") even though that node isn't connected to ground. That is not the case here. These two nodes can be at a voltage other than 0V, but they have to be at the same voltage even though they are not connected to each other. This is known as a "virtual short". The distinction is important.
  3. shteii01
    Feb 19, 2010
    3,500
    511
  4. shteii01
    Feb 19, 2010
    3,500
    511
    I got C1=0.1 uF.
  5. callum2510
    Aug 26, 2015
    9
    Do you mind me asking how you got that?
  6. MikeML
    Oct 2, 2009
    5,450
    1,066
    That is not correct either. The first opamp is acting as a multivibrator, so the inputs are almost never at the same voltage...
  7. shteii01
    Feb 19, 2010
    3,500
    511
    <br />
f=\frac{1}{T}<br />
T=\frac{1}{f}<br />
f=82 Hz<br />
    Find T.
    T is known.
    R3 is known.
    Find B.
    Plug everything in and solve for C1.
    <br />
T=2*tau*ln(\frac{1+B}{1-B})<br />
tau=R_{3}*C_{1}<br />
B=\frac{R_{1}}{R_{1}+R_{2}}<br />
    callum2510 likes this.
  8. crutschow
    Mar 14, 2008
    13,472
    3,359
    That's true if the op amp is operating in the linear mode but here it's operating as a comparator in a square-wave relaxation oscillator circuit, so the two inputs are only at the same voltage at the instant the output changes state.
    Edit: Okay, Mike beat me to it. ;)
  9. WBahn
    Mar 31, 2012
    18,079
    4,917
    Hello! Homework HELP!
  10. WBahn
    Mar 31, 2012
    18,079
    4,917
    True. I didn't consider the circuit beyond seeing the notation -- only had a few seconds to make a reply when I got called away.
  11. WBahn
    Mar 31, 2012
    18,079
    4,917
    Wouldn't it be even more helpful if you wrote up the entire solution and submitted it for the TS?
  12. shteii01
    Feb 19, 2010
    3,500
    511
    The dude is too clueless. Me solving this one little problem is not going to make him finish that class with an A. I will be very surprised if the dude can get a B for this class. My bet is on C or D.
  13. callum2510
    Aug 26, 2015
    9
  14. callum2510
    Aug 26, 2015
    9
    I wasn't looking for a answer more an explanation. Why have a homework help section on the forum if you ***** are going to criticize me asking for some help?!
  15. callum2510
    Aug 26, 2015
    9
    How the **** would you know what my academics capabilities are? Yes some questions are challenging for others hence why I approached this forum for clarification. You're just an old American wanker that loves to assume stuff without any knowledge
  16. WBahn
    Mar 31, 2012
    18,079
    4,917
    Watch the language -- that will get you banned pretty quickly.
    I wasn't criticizing you at all -- I was making remarks aims at shteii01 (i.e., the person whose post I was responding to).
  17. WBahn
    Mar 31, 2012
    18,079
    4,917
    The you are always free to go elsewhere. But obscene language won't be tolerated here.
  18. JoeJester
    Apr 26, 2005
    3,393
    1,211
    You thanked shteii01 and then quoted his post with no other comments.
    Then you went on a rant.
    Is there a question forthcoming?
  19. shteii01
    Feb 19, 2010
    3,500
    511
    Look. I was responding to WBahn.
    Generally speaking, I was rude to callum2510. I admit it. So his response does not surprise me. However! I was rude. He was rude. I got what I deserved. The original question/homework problem was answered. Lock this thread and let us all move on.
  20. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Generally threads are not locked.
    It really doesn't matter who you responded to. In your second rant, you mentioned shteii01. I personally thought it was uncalled for, so I decided to ask if there was more questions. Since there's not, my time in this thread is done.
