Waveform Generation
Discussion in 'Homework Help' started by LALFORBES, Apr 27, 2007.
  1. LALFORBES
    Apr 27, 2007
    Hi
    Can anyone help please?
    I want to use an 8038 IC to produce a square wave and triangular wave output. I am using Electronics Work Bench Multism 9. This chip is no longer available in Multism 9. Can anyone suggest an alternative or equivalent OR A different way to go about this.
    LALFORBES
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The forum is glad to help those that can help themselves. Two questions. Do you have the datasheet? Have you read it?
  3. recca02
    Apr 2, 2007
    1,211
    i only know one way of generating sq wave
    use opamp with high gain with sinusoidal i/p
    for getting sq wave.
    use opamp as integrator to get sawtooth wave with digital signal at i/p
    i dont know anything abt gen triangular ones :( will a sq wave ac wave give triangular wave???
    well what else do u expect from mech student (actually my engg course is a hybrid of mech and electrical so i am jack of to trades master of none :( )
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  5. LALFORBES
    Apr 27, 2007
    Hi Papabravo
    New to this site and first time I have posted anything!
    Thanks for reply, have data sheet and read some of it.
    I can see what it does but can't see an alternative in EWB.
  6. n9352527
    Oct 14, 2005
    1,198
    Maybe just skip the simulation and do the prototyping directly? Or you could simulate just part of your circuit, like the output amplifier/buffer.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The substitute part is the NTE864. Mouser carries them. Maybe Multisim has the template for that device.
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Creating a symbol so you can do a schematic should be straightforward. Creating simulation models is a bit more complex. You will probably get further faster if you skip the simulation on this one. Unless you can find one that is done already I think you are wasting your time on the simulation.
