Assuming the ionosphere to consists of a uniform a layer at a height of 500 km and with critical frequency 5 MHz, calculate the minimum and maximum ranges at which a 12 MHz signal mav be received by means of single-hop transmission. Calculate also the ranges at which both single-hop and double-hop transmission may contribute to the received signal lake the radius of the earth to be 6370 km.
