Watts triangle
Discussion in 'General Electronics Chat' started by Webby, Sep 6, 2008.
  1. Webby
    Thread Starter Active Member
    Jun 15, 2008
    66
    Hi all, with a 12v circuit with two 85 watt bulbs in parralel do I add the bulbs values together before calculating the current flowing or just divide by one bulb value only? Trying to work out the current flowing to use a suitable fuse rating.
    Power divided Volts = current
    85/12= 7.08amps
    or
    170/12=14.1amps
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Your second equation is correct.
    Is your 12V source capable of delivering that much current?
    hgmjr
  3. Webby
    Jun 15, 2008
    66
    Hi, see what you mean this question was on a test paper I had to compleat thats all what fuse rating would be suitable?
    If this was a series circuit i presume i use the same equation adding the bulb wattage together?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    If the bulbs were is series you would not use the same equation. Current in both bulbs would be the same but the voltage would be cut in half.
    hgmjr
  5. Webby
    Jun 15, 2008
    66
    Thanks if in the paralel circuit we have 14.1amps currnt flow what fuse would be suitable 15amps or less?
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    A fuse less than 15 amps might prove too small for the parallel case. There are no absolute standards for fuse selection but typically you are safe to use a fuse large enough to insure that the heat rise in the interconnecting wires remains below 10 to 20 degrees celcius above ambient in the event of a short circuit.
    hgmjr
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    The fuse manufacturer Littelfuse has a pretty good Whitepaper on the subject of fuses at this link.
    hgmjr
  8. iamspook
    Member
    Aug 6, 2008
    27
    Assuming this is (say) a tungsten globe, then there are two characteristics to consider.
    Steady-state - which is governed by the resistance once the bulb has reached steady temperature, and the non-linear surge that happens when you first apply voltage. For steady state - consider the resistances as lumped components. For considering surge, then
    take the peak current drawn just after voltage is applied. The resistance of the filament falls as it heats up.
  9. Webby
    Jun 15, 2008
    66
    Hi, was trying to find the answer in the "eebook of all about circuits" why would you have to half the system voltage to work out the current flow if two bulbs are in series.
    Do I add the bulb power i,e 85watts togther =170 watts divide by 6v= 28.3amps cuurent flow.
