MJ2955 - High Power PNP Silicon Transistor, T0220 (SEM62H)I'll sign off for today then aswell, getting late. when you return studiot, I'm going with your solution, definitely.
Just remember that power is voltage*current. If you size the pot properly, you shouldn't have any problem using a pot rated for 750 mW. Figure out those two things and you have your power. Don't forget to build in a cushion. When practical, never ask a component to exceed more than half of its rated power handling ability and be very leery of exceeding more than about 75%. That's just a real crude rule of thumb -- some components can be abused pretty heavily and others need to be treated with more kindness. With experience comes an ability to judge when you can be brutal and when you must be gentle.last question then I'm really off: what wattage will the potentiometer need to carry, 'cause affordable ones max out at 0.75W
hand powered, thought that's what hand drill meansIf by hand drill you mean electrically powered drill then you can.You will need 3mm HSS bit and WD40 or some sort of oil to lubricate the drilling spot.
That heatsink should work fine.
Stock Code 35M5830When you decide to buy the transistor or regulator I would recommend you to look for ones in TO220 package only.TO3 is really pain in the as* to mount since it requires 4 holes and special thermal pad so you don't short circuit the pins.
You can buy LM350 if you decide to go with regulator solution.
what would the 5V setting be on this regulator, or do I need to use a potentiometer?Stock Code 35M5830
Part Number LM350T
Description REG ADJ POS TO220 33V 3A
Manufacturer FAIRCHILD
Sold In Each
Minimum Order Qty 1.00
Alternate Part Number
Memo POSITIVE ADJUSTABLE LINEAR VOLTAGE REGULATOR 1.2V TO 33V 3A TO220
This the one?
I'm going with both solutions, education in both, and my projects are purely educational, it needs no real word application.Yes but you don't need regulator if you are going with studiots solution.You need two resistors to get fixed voltage output.Search for lm350 resistor calculator.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jeff Child
