Hand Drill, ok mm's then... what do I need to buy, if it's conceivably possible with hand drillWhat kind of hand drill?Power drill or hand powered?
Those drill bits are probably in mm's one inch is pretty big.
sorry for the big image in the post, didn't know how the system works, from now on ONLY THUMBNAILS ;-)the pics aren't that good, but should give an Idea of what I'm working with.View attachment 75625
Doesn't measure, means its more than 2000KBut before you start, do the measurements I asked for on your CCTV supplies.
I am interested in isolation between the mains input and the output, for safety reasons.
www.mantech.co.za not so easy to get there/ transport problems, this isn't the one you had in mind is it?If you are going to buy a regulator, you might as well buy an LM309K and have done with it.
You won't need the transistor then.
like the side of a computer casing?A large chunk of metal can also do pretty well..
how would I know?Anything made of aluminium will work fine as long as it has big enough size.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Duane Benson
