Wattage Carried by 161 KV Line
Discussion in 'General Electronics Chat' started by lal, Feb 23, 2007.
  1. lal
    Feb 23, 2007
    I am trying to figure out how many megawatts are carried by a 161 KV, 3 phase line. The wire diameter is .6 inches. Is there any other info that would be needed? Thanks:confused:
  2. wireaddict
    Nov 1, 2006
    133
    Yes, you need to know the current in amperes & the power factor [or cosine of the phase angle]. 3 phase power [in watts]=1.732XVoltageXCurrentXPower Factor.
  3. kubeek
    Sep 20, 2005
    4,689
    806
    Bare copper wire can take about 3A/mm2.
    I guesstimate the maximal power could be somewhere between 100-150MVA.
  4. subtech
    Nov 21, 2006
    123
    5
    In the U.S., the most common conductor for transmission line use is aluminum,or more specifically ACSR (Aluminum conductor steel reinforced) so here is your conductor info and ampacity rating per the Lineman and Cablemans Handbook.
    Your conductor diameter(true dia. of .609 in.) falls into the category of an aluminum conductor of 266.8 Kcmil (Cable code word "Waxwing") and has a nomimal current carrying rating of 430 amperes with a 40 deg. C rise over an
    ambient temp of 40 deg. C.
  5. kubeek
    Sep 20, 2005
    4,689
    806
    Well that makes 120MVA.
    I love when I am right :)
  6. tek_fool
    Feb 24, 2007
    12
