Watt-hour to Amp-hr conversion
Discussion in 'Homework Help' started by anony, Apr 11, 2010.
  1. anony
    Apr 3, 2010
    12
    hello,
    i have a system that consumes 95.76 Wh of energy. I want to calculate how many AA batteries will be required to run this system for 14 hrs
    Can some one please help me with this conversion?
    Thankyou
  2. retched
    Dec 5, 2009
    5,201
    313
    Do you know the voltage of the system?
  3. anony
    Apr 3, 2010
    12
    not exactly as its not constant. But the current is constant and its value is 40 mA
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    40mA *14 = 560mAh so in real life 1200mAh will be good
  5. anony
    Apr 3, 2010
    12
    okie....sorr but now i m bit confuse about it. what about the resistance ? If the current is constant the resistance value will not matter for calcuting the battery usage?
    and i read that AA batteries have arround 400-900 mamp-hr capacity so for my problem two AA batteries will be enough?
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well in real situation resistance do matter. Because when cell is discharge the voltage on the cell drop so current will me drop to.
    And this is so we need more mAh cell then in theory.
  7. anony
    Apr 3, 2010
    12
    the system i need to run with AA batteries is giving constant dc current of 40 mA in form of pulses ( frequency of 200 hz with high time of 120 microsec). So the On time for pulse in one hour is= .024 hr ( is it right ??)
    To calculate the AA batteries that can run the system . Can i use this equation
    (40 mA) * (.024 hr) = 0.96 mAmp-hr
    It means that one AA battery is enough ??
    and also can i calcualte the battery usuage like this?
    Thankyou
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    For F=200Hz an Ton = 120uA the average current will be equal:
    Iavr = 40mA * 0.12ms/5ms ≈ 1mA
    So you don't have to be worry about battery capacity, 400-900mAh will be enough.
