Waterpump Jepardy!
Discussion in 'Off-Topic' started by maxpower097, Apr 24, 2013.
  1. maxpower097
    Feb 20, 2009
    795
    388
    I'm a small portable DC pump that runs up to 12v. I can suck in water and pressurize it into a filter so it pumps slowly thru the filter material which is tightly packed. What kind of water pump am I?
    Custom water pump from alibaba or china?
    Waterpick pump canabalized?
    Powerhead for fishtank? or Filter?
    Would there be any that would work mechanically where you could build the pressure then cut it of with a non reverse flow tube and keep the motor from running?
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Am I an espresso machine pump?
    maxpower097 likes this.
  3. maxpower097
    Feb 20, 2009
    795
    388
    Mark77 - 5 points
    hmmmmmmmmmmmm good idea! Jakuzi pump?
  4. Brownout
    Jan 10, 2012
    2,375
    998
    I made one from a 12v self-priming pump (HFT), a pressure switch (SquareD) and a backflow preventer (Home Deopt) and various fittings, etc. It is the basis for my sailboat cool mist system.
  5. shortbus
    Sep 30, 2009
    4,084
    1,664
    Are you a pump connected to an accumulator tank, through a check valve, with a pressure switch on the tank?
    I love "what's my line" :).
    Aw, Brownout types faster. :(
  6. #12
    Nov 30, 2010
    16,656
    7,295
    Old age and treachery beats youthful naivete every time.
    shortbus likes this.
