Waterproofing Stepper Motor -- Mineral Oil?
Discussion in 'The Projects Forum' started by mechedd, Feb 21, 2010.
  1. mechedd
    Feb 21, 2010
    Hey everyone,
    I have been looking into ways to waterproof a stepper motor and I came across a video on how to waterproof a servo using RTV and mineral oil. The inner working of a servo and a stepper motor are different, and I am wondering if this technique could be used on a stepper with no harm.
    The project I am working on is a nozzle positioning system for a water fountain, and it includes three stepper motors in the design. Since they will be constantly exposed to water, I need a reliable way to waterproof them so that they will not lose functionality.
    Here is a link to the video I am referring to.
    http://www.societyofrobots.com/actuators_waterproof_servo.shtml
    Any suggestions?
    Thanks,
    Dan
  2. Externet
    Nov 29, 2005
    775
    57
  3. Kermit2
    Feb 5, 2010
    3,838
    961
    You should use a motive power suitable to that environment.
    Fluid, or even air motors, not electrical.
  4. BMorse
    Sep 26, 2009
    2,675
    234
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    You'd want to be careful about changing the thermal characteristics -- I've seen applications where stepper motors get quite warm to the touch; you'll set yourself up for early failure if you run the motors too hot.
    If the motors can be enclosed in a waterproof box (again, worry about the cooling), it wouldn't be too hard to make a shaft feedthrough that would be watertight (but it depends on the shaft's speed). See your local bearing supplier for recommendations. If it was me and the shaft speed was slow, I'd just use a couple of well-greased o-rings and make my own seal. I'm assuming you want splash-proof type seals, not immersion.
