Water Soluble Flux - Tip Corrosion
Discussion in 'General Electronics Chat' started by jack33, Feb 7, 2011.
  1. jack33
    Dec 31, 2010
    42
    I have a spool of 63/37 solder with water soluble flux core (OAJ). I thought it was rosin core when I bought it some time ago. I just now read the fine print on the spool. I tried it and it worked fine and cleaned up easily, but I have read that it can cause tip corrosion. After I finished soldering, I cleaned the tip and retinned it with rosin core solder. I would like to use it since I have it, but I don't want to damage my tips. Any advice would be appreciated.
    Jack
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Buy a small can of rosin flux (non-acid) and drag the tip through it on a regular basis followed by a wet sponge.
  3. jack33
    Dec 31, 2010
    42
    Thanks, I'll do that.
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
