Hey guys, I'm in the midst of making a water pump.
Figured you can give me some pointers.
I have the impeller, housing, shafts and everything complete.
I've tested it with a hobby grade motor that should hold 14.8v
shot water almost 6 feet, but then the spring holding the bushes bent from getting too hot.
I have a motor but I'm not sure what kind it is.
There's two copper coils around a "U" shapes pole. at one end has a magnet shaft.
I think its some sort of pulse motor.
The issue with that, is that it's too slow.
If I take out some winding's could i make it go faster. Or add less and bigger winding"s?
Edit. Just a standard ac motor I think
