Yep, my teacher used to use the term "swing rail to rail" all the time. He had a couple of pet CMOS op-amps that he liked to use as they swung virtually to both rails.Well, the term "rail" when used in electronics is kind of an anachronism; people used to start drawing schematics by making horizontal lines for +V, ground, and -V, then start connecting components between these power lines. It started resembling railroad tracks, so they started calling them power "rails".
????????????Yep, my teacher used to use the term "swing rail to rail" all the time. He had a couple of pet CMOS op-amps that he liked to use as they swung virtually to both rails.
Incidentally TI had a great doc (ref SLOA058) about how to configure op-amps in circuits if you have a single power supply etc - some good examples in there
Why 9.4uF? Is that the measured value of a capacitor with a 10uF label? Leakage depends on the type and quality of capacitor used. What would be the significance of leakage for you in this circuit? The most likely component to fail over time in a harsh environment is an electrolytic capacitor. They could dry out and effectively loose their capacitance.Dear Kmoffett,
that problem got solved thnks a lotcan u also help me in telling what will be the leakage current since we are putting 9.4uF capacitor at the input of pin 3 .how much leakage current is expected.can u also tell me possible causes of failure of this circuit in future.in short what are the shortcomings of this circuit
Reversing pins 2 and 3 reverses the output logic. The pin 7 output is capable of sinking 50mA to ground.Dear KMoffett,
also If i want to reverse the logic with same IC that is water detected VCC(12V)-0.5V and with fuel 0.5V min to 1.8max can you tell me will this IC be sufficient if i do not connect my mosfet at the putput reversal of logic is possible but how much is the output current of LM311 IC alone.
What are you testing in that circuit that the small leakage current through an electrolytic capacitor would effect?leakage current i need to know for the testing purpose.i am connecting two 4.7uF capacitor in parallel to meet my respective time delay.So i need to know how much value of leakage current can be expected how can i check the leakage current or how to calculate the same for this circuit.Kindly help
The LM311 can't do 250mA without an external BJT, MOSFTET, or relay.Dear Ken,
I know the maximum sink current which is possible is 50mA i want to increase the same current to 250mA without using mosfet .What changes i need to incorporate in my circuit to meet this new current requirement of 250mA.
actually we ve done it a long tym before,i ll try 2 get tat ckt and alldear Krishananvsalim,
Are you designing on the same concept ?
The ammeter has to be placed in series with the negative lead of the capacitor, so it measures the current through the capacitor, not in parallel withe the negative lead and ground. The way you have it now you are just measuring the current through R1 and the water, or just R1 if the electrodes are out of the water.Dear KMOffett,
i connected the ammeter between capacitor negative lead and ground and kept the range of multimeter on maximum and kept my electrodes dipped in water the leakage current was not showing it was showing a value of 1mA only is this the leakage current ?since the capacitor negative lead is already grounded .
