water level project using microcontroller circuit
Discussion in 'Embedded Systems and Microcontrollers' started by gatome, Sep 2, 2010.
  1. gatome
    Sep 2, 2010
    hi everyone. Am looking for a project on water level using microprocessor can anyone help me with the coding and the schematics thanx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might supply a few details:
    1. Track or maintain a water level?
    2. How does the water level change?
    3. Will a 6809 do for the microprocessor?
    4. What means will you use to detect the water level?
    5. To what degree of precision must the level be resolved?
    6. If water level is the only thing affected, why not simply use a float valve?
  3. gatome
    Sep 2, 2010
    tracking and maintaing a water level controlled by microprocessor
  4. elementalrage
    Jul 30, 2009
    59
    That says it all right there...
    The schematic below should help:
    *Stole it from another post that I thought was humorous. (It doesn't enlarge - that's the humor.)
