Water level Monitor
Discussion in 'General Electronics Chat' started by Phil Taylor, Feb 13, 2013.
  1. Phil Taylor
    Feb 13, 2013
    Hi I live beside a river in a very low lying house. I have been flooded twice. I would like to build a devive that monitors the water level out side my house when we are in a flood threat time. I need this device to sense a rise or fall over time of say 2m in depth and have an accuracy of 1mm scale. The average rise and or fall in flood times is approx. 1-2cm per hour. The idea would be to see if the water is tending to rise or fall over time and to set alarm points. It would be good to log the data but not esential. Has anyone got any ideas please? Phil
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    My idea would be to move to higher ground. Your problems with flooding is only going to get worse.
  3. #12
    Nov 30, 2010
    16,685
    7,323
    Learn microprocessors. It's going to require a lot of programming to detect 2 meters, within 1/10th of 1%, and log the data for days or weeks.
  4. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    its easier to buy a off-the-shelf device that does this.
  5. mcgyvr
    Oct 15, 2009
    4,789
    975
    Just buy a buoy..
    What are you gonna do when the "monitor" tells you the water is higher anyways?
  6. sheldons
    Oct 26, 2011
    616
    101
    Heres a simple circuit to try.....
  7. DC_Kid
    Feb 25, 2008
    641
    9
    when the siren sounds in middle of the night there is no need to look, you just hop in the boat ;)
  8. gerty
    Aug 30, 2007
    1,154
    304
    Is this going to be located outdoors, where it will have the tendency to freeze, or have ice form on it?
    A simple float switch such as used on sump pumps would work ,but, wouldn't have your required accuracy.
  9. crutschow
    Mar 14, 2008
    13,496
    3,373
  10. Duane P Wetick
    Apr 23, 2009
    408
    19
    You can probably make a fairly accurate reflective level sensor using off the E-bay shelf photoelectric devices; A-B or other industrial types...mount it up high enough where it won't get flooded; 20ft. may not be high enough. I live 100 ft. above the water and have never been flooded.
    Cheers, DPW [Everything has limitations...and I hate limitations.]
  11. crutschow
    Mar 14, 2008
    13,496
    3,373
    How would a photoelectric device detect water level to the accuracy he desires? :confused:
