Hi all,
I have a company made water level controller which has malfunctioned and wouldn't run the pump when water level goes low.. I guess its a broken logic.. The problem is that all the IC's have been covered by the company with a black substance to avoid local service or copying. I managed to clear 3 of the 4 chips and they were LM324, which I guess is used for the over and under voltage cutoff, a 4066 and CD4093. the 4th chip had its print peeled of with the paint and it is unable to identify.. Its a 14 pin, ST make and of the remaining details it is something like 4X9XN.. First I thought it would be 4093 but all the 4 chips on this device are from 4 different manufacturers.. the overhead tank and water souce level lines Common, Low, High and Dry Run all lead to this chip..Is there anyway to identify it??
