Water Level Comparator
Discussion in 'Homework Help' started by ac_dc_1, Jan 30, 2013.
  1. ac_dc_1
    Jan 27, 2013
    74
    I have the folowing problem:
    Consider a circuit that is able to produce a luminosity signal to warn about one of the following events: 1)water level above 90 cm 2)water level below 30 cm
    Consider that you have a level sensor with signal conditioning that outputs a voltage proportional to: V(L)=1 + 10L (L-Level in metres)
    The circuit has to be feed with 12V and -12 V.Describe the levels of tension and current so that the circuit will work correctly.
    Is this the way to solve this.Obviously this equation has no solution but my error is a mathemical one or this kind of problems are not solved this way?
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    I think you first need to be sure that you understand the problem. As I read what you have written, the light should go on if the level is above 90cm or if the level is below 10cm. The light doesn't tell you which condition exists, only that when it is lit the water level is not between 10cm and 90cm. Is that correct?
    If so, how will using a comparator with hysteresis accomplish your goal?
    Sketch what you want the output of your comparator circuit to be as a function of water level. Then annote that sketch with the corresponding voltage levels at the key points.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Complementing what WBahn said, remember that one comparator circuit, even with hysteresis, can tell you if your input signal is greater or less than your reference signal. Even if your reference signal varies, the direction principle (greater or less) still applies.
    In your case one hysteretic comparator could tell you if your water level reached a value that is greater than 90cm or lower than 30cm. No other options exist.
    Since in your problem you specified three distinct water levels, only one comparator can't cut it.
  4. ac_dc_1
    Jan 27, 2013
    74
    My problem does not specify three distinct water levels.I only need to know if the level is above 90cm or below 30cm nothing more..
    If the water level is above 90 cm the litght goes on(one transition point) if the water level is below 30cm the ligth goes on(another transition point).So with a hysteris comparator i can get those two points in order to get +vcc or -vcc in the output and then trigger the ligth with those tensions,so i do not understand why i can not use a hystersis comparator..
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Do what WBahn asked you to. Plot the hysteresis loop of your desired comparator. In the x-axis put your water-level sensor voltage. On the y-axis put the comparator output. Compare this to a typical hysteretic comparator loop, pictured below:
    The points Voh, Vol, Vcl, Vch can be placed at will.
  6. ac_dc_1
    Jan 27, 2013
    74
    I have Vcl=30 cm Vch=90 cm and Vol =4 V aND Voh=9V.It seems correct to me...If the level goes below 30 Cm Vo=+VCC and i can trigger a ligth with that voltage.If the level above 90 cm V0=-VCC.
    I think that what you are saying is that the light would always stay on if 30 cm<=level<=90 cm..But that depends on driver and contacts i use to trigger the ligth circuit....It can be normaly open or normaly closed.Doesn't that make a difference?
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    Two misconceptions there:
    1. Based on your problem description, you need +Vcc on the output both when Vin<30cm and Vin>90cm. You see that this isn't a standard hysteretic comparator behaviour.
    2. The output of the comparator, whose loop is pictured above, when Vcl<Vin<Vch is defined by the previous state.
    If Vin>Vch and then Vin>Vcl, then Vout=Vol during all of that time.
    If Vin<Vcl and then Vin<Vch, then Vout=Voh during all of that time.
    These are the only conditions that define Vout when Vcl<Vin<Vch.
    Is that clear?
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Will you PLEASE sketch what we have been asking you to sketch?!
    Let's say that the water level drops below 30cm and Vo goes to +VCC and you "trigger the light circuit" - whatever that means. When does the light go off?
  9. ac_dc_1
    Jan 27, 2013
    74
    It does not go off.Thats the problem.I thought that what defined the outout(Vo) of a hysteris comparator where the values Vol and Voh,which are defined by relationship between the resistors.So it would go off when the input tension coming from the sensor would be >= than 3V....
  10. Georacer
    Nov 25, 2009
    5,151
    1,266
    You are right in expecting to select Vol and Voh. You are wrong in the way you think the output of the comparator will behave.
    We can't help you if you don't want to be helped. Sketch your desired output function vs Vin and then we 'll be able to help you. You can use whatever means you have available: photoshop, paint or even a hand sketch.
  11. WBahn
    Mar 31, 2012
    18,085
    4,917
    And that's what we've been trying to get you to see.
    If you would just draw the sketch we have been asking you to draw repeatedly you would see why.
    No. Draw the sketch of the output of a comparator with hysteresis as a function of the input voltage and you will see why.
    Why do you refuse to do the simplest thing? It's like you don't really want any help, you want to just keep insisting that your solution, that you already know doesn't work, should work.
  12. ac_dc_1
    Jan 27, 2013
    74
    The sketch is exactly the image that Georacer posted with Vcl=30 cm Vch=90 cm and Vol =4 V aND Voh=9V.So from there we conclude that the light would be always on,so we can not use this kind of comparators.The question now is,what can i use for doing this?It has to be some kind of comparator i guess....
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    If your sketch is exactly like a hysteresis loop, then it does not fulfill the problem specifications.
    Indeed, that image displays Vout=HIGH when Vin<30cm and Vout=LOW when Vin>90cm,
    while you want Vout=HIGH when Vin<30cm and Vout=HIGH when Vin>90cm.
    Are you starting to see why a single comparator isn't enough now?
    Try to look for a circuit that incorporates two simple comparators (without hysteresis).
  14. WBahn
    Mar 31, 2012
    18,085
    4,917
    How do you conclude that the light will always be on?
    Whatever. Fine. Let's move on. You now know that a comparator with hysteresis is not what you are looking for. You are now asking what kind of comparator will do what you want. Is it NOT reasonable to know what you want the comparator to do before you start asking for the type of comparator that will do it?
    Here's an idea: Sketch what you want the output of your comparator circuit to be as a function of water level. Then annote that sketch with the corresponding voltage levels at the key points.
    Sound familiar? It's from Post #2. It's the sketch that we have been trying to get you to post from the beginning. It's the sketch that you keep not bothering to do. It's the sketch that will make it clear what you are trying to do. It's the sketch that will show what you need your circuit to do. It is NOT the sketch that Georacer posted.
  15. ac_dc_1
    Jan 27, 2013
    74
    Then conect the outputs to two buffers that will link to the power driver circuit
  16. WBahn
    Mar 31, 2012
    18,085
    4,917
    How are you going to "connect the outputs to two buffers that will link to the power driver circuit"
    You seem to be, again, jumping at the conclusion that you can connect your outputs to some unspecified and undefined "power driver circuit" that will just automatically do what you want based on what you give it. Yet you won't even clearly specify what you are going to give it, let alone define what that unspecified "power driver circuit" is going to do or how it is going to accomplish it.
    Why do you steadfastly refuse to produce the most basic sketch we have been asking for?
    I'm done trying to help you until you take the five minutes to do that simple task.
    thatoneguy and Georacer like this.
  17. ac_dc_1
    Jan 27, 2013
    74
    What about a window comparator?Would it be a solution for this?
  18. WBahn
    Mar 31, 2012
    18,085
    4,917
    Tell you what, provide a sketch of what you need the output of your comparator circuit to be and we can then start discussing whether a window comparator might be a viable solution for doing it.
  19. ac_dc_1
    Jan 27, 2013
    74
    Where it is the so desired sketch.Vout is represented in red.That curved line represents the water level.So now about window comparators?How do they work?I have never learned about this type of comparators but it seemed suitable to my problem..
  20. Georacer
    Nov 25, 2009
    5,151
    1,266
    Thank you. Was that so hard?
    To be strict, this wasn't exactly what we asked you. Also, the blue line at some point is both below 30cm and 90cm which doesn't make much sense but we get your point.
    The transfer function we wanted you to plot, was the following:
    See how different this transfer function is compared to the one from the hysteretic comparator?
    I 'd like to make sure you understand why a comparator with hysteresis wouldn't be suitable for your problem. If you don't please ask for clarification.
    Now, about the dual comparators.
    Yes, this is a good choice, especially with the LM339 OpAmps; Since they are open collector type (which means that they only sink current, they can't source any), they can't short circuit their outputs, in case they want to show a different result.
    You will need to tweak the circuit you posted, though. Remember, a comparator, will go to Voh when V+>V- and to Vol when V+<V-. Based on that, in which pins do you think that you should connect the limit reference voltages and in which the sensor output?
    You should also consider your output specifications. You mentioned Vol=4V and Voh=10V. Where did you get those numbers from? These should reflect some requirements for your load (buzzer, light etc). You should also justify this choice.
    Finally, the LM339 needs to operate with a large resistor from Vcc to its output (thousands of ohms). This will constrain its drive capabilities. Consequently, you will need another driver stage after the comparators, which will depend on the load.
