It should be okay, as long as you make sure it's COMPLETELY dry. To do that, I'd suggest removing the back of it and blow-drying it from that angle, as well as the top. You might have to peel some of the rubber/plastic back in order to dry it completely. Just make sure there's no water that can spread between rows of holes.Hey guys,
I accidentally spilled some water over my protoboard. If I blow over it with a hair dryer for a few minutes, should it be fine to use again?
You might want to let her know before she turns it back on to bake her cookies though....Remove part following morning. Don't let your wife know.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Aaron Carman
