water flow rate in a river
Discussion in 'General Electronics Chat' started by IGBE, Feb 20, 2010.
  1. IGBE
    Feb 20, 2010
    pls i am trying to design /construct a device that measures volume flow rate of water in a river every one hour. this device should include a memory storage and a digital display for the values measured. the storage should be such that the values optained one hour ago can still be viewed now.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. studiot
    Nov 9, 2007
    5,005
    515
    You need to construct a speciallly shaped river channel at the point of flow measurement.
    Normally the height of flow above a sunken weir is measured.
    So you need to design a depth gauge.
    Are you designing the electrical engineering or the civil engineering?
    The process of flow measurement is called river gauging.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Flow "volume" requires a cross-sectional profile of the river at the point of measurement, as well as the flow rates at various depths. Our Geology/Biology field teams use a flow profiler with a differential GPS to record the data, as the sensor is moved across a river in a boat . $$$$$
    Ken
