Watchdog Timer with Stay Low Output
Discussion in 'Embedded Systems and Microcontrollers' started by jmsayles, Jan 17, 2016.
  1. jmsayles
    May 21, 2013
    Does anyone know of an IC that functions like a watchdog timer only with an output that stays low until it is reset rather that pulsing low?
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    555.
    WD timers usually present one state at the occurrence of pulses and will go high or low when alarm out, is this what you need?
    Max.
  3. jmsayles
    May 21, 2013
    Yes, but I was hoping to find something in a single IC that does not require all the supporting discretes.
  4. sailorjoe
    Member
    Jun 4, 2013
    361
    63
  5. jmsayles
    May 21, 2013
    Thank you SailorJoe. I have looked through several spec sheets on watchdog timers and have only found ones that pulse low, i.e. send a uC reset signal, rather than just stay low. Basically, I am looking to send a signal to the master controller that this uC has locked up.
