Watch demagnetiser.
Len33
Joined May 13, 2015
Hi!
Does anyone have (Or know of) a proven circuit for a 'Ringing Choke' or 'Resonant Coil Demagnetiser' for use with demagnetising watches?
Thanks.
Len33
alfacliff
Joined Dec 13, 2013
2,458
have you got an old transformer type soldering gun? the wellers have quite a magnetic field. just push the trigger with the watch against the housing, and pull the watch back away before letting go of the trigger.
DickCappels
Joined Aug 21, 2008
10,187
I don't have a ready design but I can tell you that you would need to have a high Q inductor and a good quality high voltage capacitor. The capacitor is charged up then dumped across the inductor, causing a damped sine wave current oscillation through the coil. Getting a high enough Q so you do note leave more residual magnetism than you want while leaving a way for the flux to exit the inductor, go through the object being demagnetized and back into the inductor at the same time can be challenging. A digital or storage scope with a current probe would be a useful tool.
