Wat is this inverter called?
Discussion in 'Homework Help' started by zenov, Mar 24, 2008.
  1. zenov
    Mar 24, 2008
    hi, wld appreciate if someone can tell me the name of this circuit. i'm investigating the DC characteristics, wat elements am i missing in there? is the VTC supposed to look like that of a CMOS inverter?
    thanx ;)
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    You have an odd looking Mosfet symbol. A battery with an arrow pointing in the wrong direction.
    If both Mosfets are the same then they are not complementary like in a Cmos inverter.
    It looks like you have a current-source at the top that feeds a Mosfet inverting transistor at the bottom.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It's a ratioed logic inverter. M1 is always on (although it should switch of as Vout gets close to Vdd). When Vin is high, Vout is pulled down to GND and there is a current path from Vdd to GND through M1 and M2. When Vin is low, M2 is off and Vout is pulled up to Vdd.
    It is very like pseudo-nMOS where the pulll-up transistor is a pMOSFET with the gate to GND.
    Dave
  4. zenov
    Mar 24, 2008
    wow! thanx for pointing out the mistake in my diagram, and thanx for explaining :)
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    There is no mistake in your diagram, it is just a particular arrangement of inverter using nMOS transistors.
    Dave
