We have recently had a thread about a burning smell in a power supply
http://forum.allaboutcircuits.com/showthread.php?t=86899
My washing machine has developed a burning smell so I looked inside.
The culprit was the mains input filter assembly.
The burning can be seen at A.
The mains comes in via the white lead at C. This enters the filter unit D in a sealed manner so the connections are not accessible.
Wires B pass the line (brown) and neutral (blue) into the machine.
Note the melting on the line wire.
Because of some of the internal wiring and the white connector B are damaged I need a new part wiring harness (£17) as well as a new mains cable and filter assembly (£20).
The circuit diagram of the filter can be seen on the white label to the left of D
