today one of the guys from work disconnected the wires going into a motor turn off the breaker feeding it whitch it was like 100 ft. away.put one of the leads from a megger into the wire where the load was and the other into the frame of the panel once he push the button of megger it showed as bad do you guys think he used the megger correctly to test the insulation of the wire
