warnings are removing all my output HELP needed very badly.....
Discussion in 'Programmer's Corner' started by beat05, Mar 21, 2012.
  1. beat05
    Sep 29, 2008
    iam using HSPICE coding in mentorgraphics and simulating in ELDO....
    the following is the comments after simulation and due to warning iam not able to get the o/p ports at all... please help awaiting you reply
    sincerely
    M.S.Chandra Sekhar
    ***** ANALYSIS ....
    Warning 439: In file "./controller.spi" line 44:
    + COMMAND .SETBUS: last Time point ignored.
    Warning 439: In file "./controller.spi" line 45:
    ***** 0 error(s).
    ***** 2 warning(s).
    ***** GENERATION ...
    Warning 107: NODE "RAS[1]": Less than two connections.
    Warning 107: NODE "RAS[0]": Less than two connections.
    Warning 107: NODE "CAS[1]": Less than two connections.
    Warning 29: Such messages will not be displayed in future. Set .option MSGNODE
    = 0 to receive all such warnings.
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_R
    EFRESH not declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_A
    CTIVE not declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_P
    RECHARGE not declared
    UTOREFRESH not declared
    EAD not declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_W
    RITE not declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.R0 no
    t declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.R1 no
    t declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.C0 no
    t declared
    Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.C1 no
    t declared
    ***** 0 error(s).
    ***** 23 warning(s).
    this is the way I wrote the code....please help me I am new to this HSPICE and I followed manual properly.
    .SETBUS RAS[1:0] RAS[1] RAS[0]
    .SETBUS CAS[1:0] CAS[1] CAS[0]
    .SIGBUS RAS[1:0] 3 0 0 0 00111111
    .SIGBUS CAS[1:0] 3 0 0 0 11111111
    Vreset reset VSS pattern 3 0 1n 0.1n 0.1n 10n 10111100
    Vrefresh refresh VSS pattern 3 0 1n 0.1n 0.1n 10n 01001011
    Venable enable VSS pattern 3 0 1n 0.1n 0.1n 10n 11110000
    Vrd rd VSS pattern 3 0 1n 0.1n 0.1n 10n 00110011
    Vwr wr VSS pattern 3 0 1n 0.1n 0.1n 10n 10111011
    Vconflict conflict VSS pattern 3 0 1n 0.1n 0.1n 10n 10011001
    V77 VSS 0 0
    .tran 10n 200n 10n
    .plot tran v(*)
    .probe tran v(controller.sdramcontroller1.out_refresh)
    .probe tran v(controller.sdramcontroller1.out_active)
    .probe tran v(controller.sdramcontroller1.out_precharge)
    .probe tran v(controller.sdramcontroller1.out_autorefresh)
    .probe tran v(controller.sdramcontroller1.out_read)
    .probe tran v(controller.sdramcontroller1.out_write)
    .probe tran v(controller.sdramcontroller1.R0)
    .probe tran v(controller.sdramcontroller1.R1)
    .probe tran v(controller.sdramcontroller1.C0)
    .probe tran v(controller.sdramcontroller1.C1)
    .end
