Warning on assembler variables
Discussion in 'Embedded Systems and Microcontrollers' started by atferrari, Feb 20, 2011.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,666
    784
    MPASM - I am working with two complex macros (three nesting levels).
    I define the assembler variables used in the macros with VARIABLE or SET or LOCAL, but always, after building (successfully) I get hundreds of this:
    Warning[207] D:\FILTER 00\007 MACROS 04.ASM 37 : Found label after column 1. (TAPAB)
    ALL the assembler variables used show up in the warnings.
    Is this a bug? Or there is a mistake from my side..[​IMG].?!
    Before resorting to errorlevel, is it there something else I could do?
  2. be80be
    Jul 5, 2008
    432
    57
    You have misspelled opcode
  3. atferrari
    Jan 6, 2004
    2,666
    784
    I know that standard reply coming from the Help but an assembler variable is not an opcode in my case:
    This is the "offendig" (?) line.
    tapev=tapev+1
