wanted c compiler
Discussion in 'Programmer's Corner' started by srinath.msd, Sep 19, 2011.
  1. srinath.msd
    Sep 19, 2011
    5
    hey guys i'm in urgent need of a C COMPILER for windows XP 32 BIT... plus the program for implementation of a SINGLY LINKED LIST. any help would be appreciated :) :)
  2. ErnieM
    Apr 24, 2011
    7,436
    1,625
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. DumboFixer
    Feb 10, 2009
    219
    34
    Why not use the STL (Standard Template Library) that includes an easy to use link list mechanism ?
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    I use MinGW on Windows when I need a C/C++ compiler. If you just need a linked list, there are a gazillion libraries around the web. If you need to write one as a class assignment, consult any beginning algorithms/data structures text and you'll learn all you need to know. The rest just requires a bit of thinking and is somewhat of a rite of passage for all beginning programmers. A good exercise is to write a doubly-linked list library tool for yourself, as you can use it to implement other data structures.
