Want to buy a Linux based laptop/computer for programming
Discussion in 'Off-Topic' started by Hunter Neumann, Nov 20, 2015.
  1. Hunter Neumann
    Aug 24, 2015
    53
    Any suggestions? I already have a macbook pro but I want to buy a Linux laptop/TABLET** not desktop for my programming classes starting in the spring. I have seen a Python S2 tablet from ekoore that looks promising, but have not found one for sale. Id like to spend under 400$. I want one because Linux is open source and I think I should get familiar with the OS.
  2. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    Best look for an outdated laptop, as linux will likely not have the drivers for the newest types.
    The following pages will give you a lot of information on the compatibility of linux for the hardware:
    http://www.linuxcompatible.org/
    http://www.linux-laptop.net/
    Depending on what you want, you could have a look at the following distros:
    If you want to build the linux from scratch : https://www.gentoo.org/
    If you want a free red-hat based linux : https://www.centos.org/
    If you want a simple small linux : https://www.linuxliteos.com/
    If you want a full featured linux : https://www.opensuse.org/
    Bertus
  3. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Excellent idea!
    Now, here's the hard part: just about any Linux based laptop is going to be the same, or more, expensive than one with Windows. Why? Because the Windows computers ship with crapware that the publishers pay to have installed on the computers during manufacturing, thus lowering the overall cost to the manufacturer.
    Luckily, Linux will run on just about any contemporary hardware you can buy. So, get a decent Windows laptop within your price range (yes, you will be paying a Redmond tax), and install Linux as a dual boot (I use Ubuntu -- though there are lots of choices). Then, you'll have the best of both worlds at a lower overall cost to you.
  4. nsaspook
    Aug 27, 2009
    3,013
    2,367
  5. joeyd999
    Jun 6, 2011
    2,757
    2,932
    This is mostly not true anymore. But it always pays to check compatibility *if* the manufacturer is willing to publish enough detail about the underlying hardware.
    One could always test with a Live USB and return the lappy if it don't work.
  6. nsaspook
    Aug 27, 2009
    3,013
    2,367
    For a programming machine just about any Intel (they open sourced the drivers to sell hardware) chipset laptop will work. You won't have super-speed graphics for games but that's not what the machine is for.
    Hunter Neumann likes this.
  7. Hunter Neumann
    Aug 24, 2015
    53
    any suggestion on a laptop that would run it well?
  8. Hunter Neumann
    Aug 24, 2015
    53
  9. nsaspook
    Aug 27, 2009
    3,013
    2,367
    Go to a site like Newegg and select for laptop, Intel chipset and price
  10. wayneh
    Sep 9, 2010
    12,388
    3,245
    Why not use your Macbook and spend nothing?
  11. Hunter Neumann
    Aug 24, 2015
    53
    do you think I could run it off of a TB harddrive well? I dont want to partition the memory on it
  12. wayneh
    Sep 9, 2010
    12,388
    3,245
    I think it is very likely, although not simple and easy. The details will depend on your particular machine and on what methods you can find to follow. It certainly has been done.
  13. Hunter Neumann
    Aug 24, 2015
    53
    do you think it is worth spending money to learn on a linux based system? or should I just learn on osx?
  14. Hunter Neumann
    Aug 24, 2015
    53
    http://www.amazon.com/Asus-VivoBook...&qid=1448048403&sr=8-2&keywords=ubuntu+laptop
  15. GopherT
    Nov 23, 2012
    6,315
    4,035
  16. joeyd999
    Jun 6, 2011
    2,757
    2,932
    One can spend money to learn anything he wants, I suppose.
    Or, one can teach ones self by taking advantage of the unlimited quantity of information available for free regarding Linux, including the source code.
    Hypatia's Protege likes this.
  17. tindel
    Sep 16, 2012
    576
    196
    I second the raspberry pi with remote access.
  18. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
  19. mcgyvr
    Oct 15, 2009
    4,791
    976
    You didn't state what type of programming you are doing..
    And you can write programs on any computer/OS.. No reason you must have linux.. Even more so if you can't afford to spend money.
  20. wayneh
    Sep 9, 2010
    12,388
    3,245
    The tools you need are likely recommended in the course descriptions. You will likely be using some specific language(s) and you'll need to run specific applications to be in synch with the class. Figure out what you need to run those applications. Sometimes there are several ways to skin the cat but usually in a school situation you want to go with the herd, or you risk having to develop workarounds at critical times when you are under stress to get a project done. Not cool.
