want pic project
boby4u
Joined Jun 1, 2007
26
I had started learning pic microcontroller a year ago and have leared to do some projects.Now I am looking for some different projects I googled the web but found only some ordinarily projects. where can I find a uniqe one.
thanks.
Papabravo
Joined Feb 24, 2006
21,225
I think the only way to find a unique one is to design it yourself. You should give yourself a chance to see what you can accomplish.
lightingman
Joined Apr 19, 2007
374
Hi...The good thing about PIC's and projects in general are being proud of your work at the end of it......It feels even better if it is all your own work.....Now think of a task that you would like to do, think of the best way you can of doing it, think about it more, make some notes and diagrams, look for the devices that will do the job........ then sit down and design it and try to see it out to the end...... Best wishes and good luck.....Daniel.
JoeJester
Joined Apr 26, 2005
4,390
Some have thrown out ideas of their design and the time they had to do the work. Members have provided feedback on how ambitious the project was, some potential pitfalls, and their feelings concerning the time constraints.
Don't let the instructions to design it yourself hinder you from posting.
Papabravo
Joined Feb 24, 2006
21,225
And the OP still has the option of continuing his search for a unique project. Maybe it will be enough to modify an existing design. I just don't know an easy way to satisfy his need for a unique project.
hgmjr
Joined Jan 28, 2005
9,027
If you are interested in robotics there are a variety of different directions you could explore. Robots don't necessarily need to roam. Headbots are an example of robots that react to their environment using sensors to measure things like temperature, light, distance, sound, and pressure.
hgmjr
i always wanted recreate the ipic web server with a mini-sd card slot. and make it so that it can plug directly into a router instead of having to go through a serial port. the only reason i havent done it yet is because i have absolutelynno idea what im doing
Perhaps start with flashing an LED. Learn the basics or you'll never be able to do a more advanced project like a PPP or TCP/IP stack.
