want a solution for Variable O/P voltage SMPS
Discussion in 'General Electronics Chat' started by maheshjalgaonkar, Sep 14, 2012.
  1. maheshjalgaonkar
    Sep 14, 2012
    sir,
    I want to design a SMPS with variable O/P voltage eg. 4-30V with variable current eg. 0-3A.
    So sir I am confuse which topology is suitable for this application. please suggest me some solution. And if u have any reference then please forward me.
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Have a google for LM317 and LM338 circuits. :)
  3. Dodgydave
    Jun 22, 2012
    5,130
    766
    For SMPS you need to be using a pwm chip like the ones in an ATX psu,
    KA7500B http://ashleymckay.com/ashleymckay/cms/sites/default/files/KA7500B.pdf
    or TL494, http://www.datasheetcatalog.org/datasheet/motorola/TL494.pdf
    (note these are the same pinouts just different makers)
    for smaller currents up to 5a you can use the TL2844. these are found in a Laptop psu.
    http://www.datasheetcatalog.org/datasheet/texasinstruments/tl2844.pdf
    here is a site with atx schematics http://danyk.wz.cz/s_atx_en.html
    I modified my atx psu to variable so you can save your self a bit of time and get an old psu and modify it for starters.
    It will give you an idea of how to design them.
    here are my videos, http://www.youtube.com/user/DodgyDavez?feature=CAQQwRs=
    absf likes this.
  4. Manish Anand
    Jun 13, 2011
    5
    See LM2576 datasheet.It's a 5 pin SMPS IC.There is a workable circuit available to suit your requirement
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    Do a standarad buck regulator using the simple switcher series like LM2576 or newer variants. The design software will pick all the components for you.
