Want A Counter Having Reset Button And Range Up to 9999(4 digit 7 seg.)
Discussion in 'Homework Help' started by aq_rules, Jun 24, 2010.
  1. aq_rules
    Oct 28, 2009
    168
    I want a schematic of such type of counter having the reset button and a count button(it will act like a trigger or it will be a push button),LCD displays a number everytime tht button is pressed..if tht button is pressed 5 times it displays 5 on the LCD
    Max Count will be till 9999.
    Plz help Me..
  2. retched
    Dec 5, 2009
    5,201
    313
  3. aq_rules
    Oct 28, 2009
    168
    how to write these files to an IC??
  4. retched
    Dec 5, 2009
    5,201
    313
    You write them to a uC (microcontroller) like a PIC.
    You will need to use a PIC programmer like a PICKIT2.
    There are many other programmers available. You may ask a friend to use theirs, or you can upload the code to microchip.com and they can program the PIC and send you the chip. That way you dont need to program it yourself.
  5. n1ist
    Mar 8, 2009
    171
    16
    If you don't want to use a micro, look at the ICM7224 chip. You may need to add some debouncing to the count input.
    /mike
  6. aq_rules
    Oct 28, 2009
    168
    i dint understand, wht kind ov debouncing...
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Something like this...
  8. retched
    Dec 5, 2009
    5,201
    313
  9. aq_rules
    Oct 28, 2009
    168
    If i use a relay instead of a push button or switch will it work??
    This relay will be connected to a infrared beam barrier circuit(having two parts)...for example a person passes through tht barrier with an average speed the relay will be active until the beam is not in contact with the other part of circuit..as the beam contacts other circuit relay goes off...plz rply soon
  10. retched
    Dec 5, 2009
    5,201
    313
    Relays still bounce. You need to de-bounce the signal from the relay. If you dont, you may count 3 or 5 or 15 counts for every 1 your trying to count.
    I suppose you could use a SSR (Solid State Relay) to avoid bouncing.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    They latch on when using DC.
  12. aq_rules
    Oct 28, 2009
    168
    shall i use a solid state relay?
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    By "latch on" I mean that the SSR will remain on once triggered until power is removed from the circuit. That is not good pushbutton behavior.
  14. retched
    Dec 5, 2009
    5,201
    313
    beenthere is correct. You will have to cut power in order to "turn-off" the relay.
    There is a whole internet out there with circuits and topics on de-bouncing.
    If you do a search in the forum, you will find many ways to de-bounce the switch.
    If you find one that looks like you can handle, post it and we will see what we can do.
  15. aq_rules
    Oct 28, 2009
    168
    what about two plates of steel contacting together when displaced ?? i own re rolling mill in which we manfacture iron rods(used for construction)...when a iron rod comes from the machine displacing that steel plate over the other plate acting like a switch will it create any de bouncing thingy??
  16. tom66
    May 9, 2009
    2,613
    214
    I think you're talking about an SCR, silicon controlled rectifier, or a TRIAC, triode for alternating current. A solid state relay is just a MOSFET with its gate light coupled. A solid state relay does not latch, unless it is particularly designed to, or unless latchup occurs... if that even happens with an SSR.
    You will need debouncing on pretty much any switch unless it is specifically designed to not bounce (it might be mercury wetted for example) or it already has debouncing logic built in (unlikely.)
    If you want a discrete simple solution, you can use 4x CD4026 (or similar 4026 series) ICs. Each IC handles one digit and increments the next counter at tenth the rate of the input signal. Wiring them in series, with the "ungated 'C' segment" output wired to the input of the next counter would be a simple system, though it has its costs, and there is no easy way to record the input using a microcontroller or handle special cases like counting two at a time, it's a simple solution. Sometimes the simplest solution works best. A reset button could wire to pin 15 of the ICs, or it could temporarily switch off power to the chips (think pulling down the Vcc of the chips.)
