Hi ,
I think this is a pretty straight forward question but want to double check before I do it I have a wall power supply (3 pin uk ) I use it for a guitar pedal on my pedal board...It rates 240v to 12v 200ma with 2.1 power jack input which is centre negative...
As I don't have a 3 pin plug socket on my pedal board I was wanting to open the wall power supply transformer up disconnect the cables to the 3 pins that would go into the wall and then attach these cables to a suitable mains cable to go into a IEC socket on my pedal board, I then have a cable with a fused plug that goes into the IEC socket.
I would keep the main case of the power supply and mount it under my wooden pedalboard, the Power supply is not sealed but screwed together
Thanks in advance for assistance and your knowledge
Jay
Jay
