Wall Adapter with Earth Ground
Discussion in 'The Projects Forum' started by John Luciani, Nov 26, 2008.
  1. John Luciani
    Thread Starter Active Member
    Apr 3, 2007
    477
    I am looking for a source for wall adapters that bring out the earth ground
    connection in the output cable. I require new adapters (not surplus)
    with agency approvals. The vast majority of wall adapters do not
    bring out the earth ground connection.
    For an output voltage I can use either 5-12V AC, 5-15VDC,
    or a dual DC supply 5-15V. A current from 200mA to 500mA
    is fine. For a DC supply connecting the earth ground to the common
    is fine.
    Thanks.
    (* jcl *)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Are you needing quantity, or would surplus (one of a kind) work?
  3. studiot
    Nov 9, 2007
    5,005
    515
    Hi John,
    Don't know about the States, but over here many commercial AV suppliers source these as AV equipment often has a separate earthing terminal on the back.
    (Perhaps this is even your intended application)
  4. John Luciani
    Apr 3, 2007
    477
    New + quantity + agency approvals.
    (* jcl *)
  5. John Luciani
    Apr 3, 2007
    477
    If you happen to have any urls please post them.
    Thanks.
    (* jcl *)
  6. studiot
    Nov 9, 2007
    5,005
    515
    I'll look round, but our wall adapters have different mains pins so I can see them being of any use?
  7. John Luciani
    Apr 3, 2007
    477
    Thanks. If you find the name of a manufacturer I can contact them to see if they
    make a US version.
    (* jcl *)
